For simplicity sake, you might completely disassemble and clean the parts, buy a new can cap and wire and reassemble according to the original dynaco instructions. Dynaco's manual was truly idiotproof. Then you can mod or not.
Personally, I would buy a new board kit. You will get better sockets and a much better made board. Those phenolic boards are like old dried out Graham crackers. Brittle and weak.
Ditch the can cap. Replace the ones in the cardboard tubes too. Those old style components aren't really obtainable anymore, and frankly they do not age well so I wouldn't go seeking NOS ones either. On some level you're going to have to accept that this will not look how it did in 1965 or whenever it was made.
If you do want it to look like it did, you're probably going to have something that is really only suitable for shelf decoration. I wouldn't be inclined to run an all-original amp on a regular basis for fear of it having a meltdown.
The residue on the tube sockets is probably solder flux. If it chips off with a little bit of poking and is an amber sort of color, thats what it is.
Don't sacrifice safety for originality. If at all in doubt, replace the power cord. It is only wire and unlike Fisher power cords with the molded on emblem, there is nothing special about the original.
Shelly_D
The switches are probably available in a current production that looks identical.
+1 on replacing the board with a 6U8 type. Even thou you can find old 7199's they are most likely heavily used and near the end of their sonic life.
Besides getting a new board will solve a number of "ills" You can order an assembled board from VTA.
http://www.tubes4hifi.com/ST70.htm
Don't get the 6SN7 board unless you are willing to do more modifications then just drop in the new board.
I never heard the VTA in a 70, only a 120.
I prefer the stock board in a 70 to a VTA in a 120.
I wound up with two OS long plate 12BH7's and a NOS Tungsol E80CC in the center. I tried the 12BH7 in the center, along with many others, and the E80CC long plate won out.I (also after extensive rolling) also preferred the 12BH7s in that board.
The long black plate RCAs specifically!
Or there. I was thinking Mouser or one of the other usual suspects. They're cheap no matter where you shop really.
Keg recommended those to me. I tried a few variants. Came back to the BH7s. I also swapped in the octal board. I had (have) a lot of respect for that amp . I did move it. One other thing Keg said to me . Its not for everyone.I wound up with two OS long plate 12BH7's and a NOS Tungsol E80CC in the center. I tried the 12BH7 in the center, along with many others, and the E80CC long plate won out.
I've had a number of the original ST-70's during the early years of ebay. Yeah, when you could buy a Dynaco for $100 or so. At that time I did try a number of the available replacement boards as well as the "supped up super modded" version boards. I never cared for the big high end boards and always came back to the BASIC (non 7199) replacement boards.Keg recommended those to me. I tried a few variants. Came back to the BH7s. I also swapped in the octal board. I had (have) a lot of respect for that amp . I did move it. One other thing Keg said to me . Its not for everyone.
While i never had them both at the same time, (memory is a funny thing) I'm more satisfied with the (basically) bone stock 70. (again different iron, output tubes, . Except for basic topology, a different amp.
EXACTLY and well put.I think the consensus was make it work with the stock board and see what you think.
I think you could start a whole new thread on after market driver boards (I'm sure it's been done already)
I'm also reasonably sure there's no consensus on which after market board is best. (Purely subjective)
As you saw in the brief friendly exchange even with the same after market board, you won't get consensus on tube choices.
It will come down to your ears.
You need a starting point.
You have to address the PS anyway.
Fix it stock. Listen to it.
If you think its not what you want it to be, have at it.
Most importantly, enjoy the journey.
About the tube sockets, I would replace them all since you have it apart. Why take a chance of blowing a good (expensive) power tube. I used the Japanese , silver plated ones from Angela Instr. The 7199s are not as critical but.......I am a bit torn on this angle. I fully understand the equation of old tube 7199 becoming harder and harder to find. However it is far from unobtainium as some suggest, more that it commands a premium due to availability. The actual struggle I am really having is whether to replace the board at all? My soldering skills and equipment are of a novice level, and I am dubious of reworking the original board myself for fear of the traces lifting or otherwise mucking it up as I have read repeatedly. Seems replacing board (oem design) with a more recent production/materials/pre-populated is the easiest approach, but does veer a bit away from oem? I would love to find some like minded AKer local to me who has the skills needed to rework the original board, and as Ferninando said
So again, if anyone local to me (Southern NH) is of a mind to give me some assistance with this, I believe I would like to keep the oem board and rework with fresh components. I would be happy to drive to or host an afternoon of board rework.
As promised, a few more pics of the disassembled guts of this thing, first the transformers.
and again, all I have done is extract from chassis (desolder not cut wires) and of course I tagged and recorded all leads. A bit of mild cleaning and a coat of wax leaves these in very presentable condition and I am not even considering repaint. I much rather the romance (and appearance) of original, a little beat up as opposed to a perfect appearing repainted anything.
The choke shows no evidence of overheating and I have done virtually no cleaning prior to taking this picture.
and I have seen a 65 on this and all transformers as well. Safe bet it was produced in '65 yes?
Then this pile of pieces/parts is all in decent shape, depending on final decision of board approach will dictate just how much of this gets undone. I will get new (oem style) switches for power and m/s. The fuse holder is not oem I am told so will effort an oem style (or original) if available. I have not taken close ups but a question about the tube sockets. On one side it appears as there is some crusty remnants on the top surface of the sockets. Not a lot, but definitely there. The other side pair is clean to the original surface and no evidence of crustiness. In the below pic the bottom pair of sockets is the clean pair and the upper shows the crustiness. I will get some better pics of this later but thought I would mention now.
Then there is the cap can. Again I did not take close up but there is definite evidence of crusty leakage coming out of the bottom of this thing. Forget the romance, just replace with a new version unless someone has other ideas?
My real quandary is about the cord. I suspect I can clean this original one and reuse, but I am leaning towards replacing (and grounding) cord with something a bit more substantial. Where do I draw the line for keeping it original?
Folks, I greatly appreciate the input here.
Geoff
I like my VTA amp. If an original Dynaco fell into my lap I would rebuild it stock with all new caps and resistors. But, I think I would use a new stock configured board. Better sockets and better made board. With the VTA ST70 I built I used the 12au7 board. Many different tubes can be tried and with adaptors you can still use 6SN7 octals. I completely went through a FM3 tuner and those old boards were a pain to work with. The traces were fragile and so were the boards themselves. If the single all in one board available wasn't so expensive I would have used it.I think the consensus was make it work with the stock board and see what you think.
