ST-70 Custom Died - Where To Start?
For some reason i believed amp was fixed and went home to Hal (parallel thread maybe:idea:)
This amp was so heavily modded too. One of the caps was bad (pic in thread) but wasn't sure on the outcome. Will see if the technician replies.
The amp was fixed and returned to Hal. He decided to sell it, it sold on Bartertown several days ago.
Yes, shipped it to an AKer in Honolulu (ouch, expensive shipping for him). He has experience with tube amps, and can do repairs himself. Unfortunately, a loose transformer screw (or nut?) caused him electronic problems, but he was able to repair it within a few hours. I included a bunch of new tubes in the purchase, and I think one of them flashed due to the short caused by the screw. He has other amps and was in no hurry to get it into his system, but advised that he'd let me know what he thinks of the sound in a week or two.
I sold it simply because I run an amp almost all the time, 24-7, and decided to forego tubes as not being as compatible as sand for that sort of duty.
Hard to argue with that logic. Tubes are fairly reliable, but for sheer hours of operation without degradation solid state wins.
Perhaps I just found why I shouldn't own a tube amp. Music was playing, at low-ish volume. My wife was standing beside the amp and I was looking at her, in conversation. There was no flash, no pop or buzz or noise of any kind. No odors. The music quit playing, the tubes faded. Won't fire back up. Should I even try replacing any tubes? Or just try to find a tech? I own a multimeter, and there ends my knowledge base.
A rustnrot (Tom Lang) build, following info provided:
Here is an amp I recently completed. Everything on this amp is new except for
reusing original Dynaco A470 output transformers. This amp uses a Classic Valve
Design "Dynamull" board http://www.classicvalve.ca/docs/DynaMull_docs.pdf
However, the input 6EJ7 tube is connected as a triode rather than a pentode, in
my opinion, even better sounding.
For a chassis, I did it differently this time so as to have the inputs, outputs,
and power connections on the back panel.
Individual bias pots are accessible from the top and test points for each tube
are accessible from the top adjacent to each output EL34 tube.
This amp also uses a MUCH more capable power transformer and also utilizes solid
state power supply rectification for increased capacity. The capacitor boards
are of my own design and use surface mount high voltage ultrafast rectifiers.
I get continuous output power of 45 watts per channel RMS with both channels
being driven simultaneously...
Detailed instructions for setting the
output tube bias will also be included as well as a schematic diagram.
The DynaMull driver board is a Classic Valve Design adaption of the
Mullard 5-20 circuit for the Dynaco ST-70 with some modernization.
Two main differences are the choice of input tube and the Constant
Current Source (CCS) in the tail of the phase inverter.
Why the EF184/6EJ7? It is a fantastic tube with clean sonics, low noise
(brand dependent) and a lot of transconductance.... significantly more than the
EF86. It is also cheaper and easier to find.
The CCS in the tail of the 6FQ/CG7 is a "no brainer" - superior
performance AC and DC. A time-tested cascode design that we and others have
used successfully for years. Proximity to the 6FQ/CG7 keeps temperature
nearly constant for minimal temperature coefficient drift.
We have attempted to keep to the classic design overall, as it already is
one great sounding circuit.
View attachment 830906View attachment 830906
Assembling the PCB is fairly straightforward and needs no adjustments or
alignment when complete.
Numbering of the off-board connections is the same as the original ST-70
board for simplicity. The only difference is the grid bias resistors for the EL-34's
are each brought out to their own pad should you wish to use our ST-70 power
supply board (or your own circuit) for balancing of the power tube bias
(instructions for such provided on the ST-70 power supply board
documentation). Should you use the original ST-70 bias circuit, which only
provides bias for left and right channels, tie the two pads labeled "21" together,
as well as the pads labeled "6" together and run a wire to their respective bias.
Image for this shown later.
Due to the density of the board, certain components must be installed
before others. Here is the procedure (components mounted on the top side of
the board unless noted):
- Install C101 and C201 on bottom side of the board
- Install R103 and R203
- Install R115, R116 and R215, R216
- Install R110, R111 and R210, R211
- Install C105 and C205
- Install C103, C104 and C203, C204
- Install R105 and R205
- Install D101, D102 and D201, D202
- Attach heat sinks and insulators (if used) on Q102 and Q202
- Install Q101, Q201 and Q102, Q202
- Install R113, R114 and R213, R214 on bottom side of the board
- Install remaining top-of-board components.
- Install remaining bottom-of-board capacitors
- Install sockets
C107, C108 and C207, C208 require "spaghetti" on parts of their leads to
keep from shorting out on some components, if you have used small pin-spaced
capacitors (we used Panasonic ECW, which are small). Suggestion is shown
below.
The wire "spaghetti" can be a piece of insulation stripped off a wire with
600V rating, actual radio-TV spaghetti, or even 1/16" walled polyurethane
pneumatic tubing available from a commercial supply house (the volts/mil
breakdown of polyurethane is very high - just don't use it on components that'll
get hotter than ~70C.).
While we are on the subject of smaller or larger pad spacing components
(often capacitors), there is a right and wrong way of mounting them for reliability.
Wiring
Now that your board has the components mounted, you need to prepare
the filament wiring.
Each socket has unnumbered pads for filament connections. The
6FQ/CG7 tubes also have a pad on pin 9. The pad on pin 9 of the 6FQ/CG7
tubes can have jumpers to ground. Some brands of 6FQ/CG7 tubes have a
shield between the sections that is to be grounded. Other brands have no shield
and the pin floats free internally. Better to ground this pad than let it float (we
didn't do this on the PCB because some experimenters like adding a small
negative voltage here).
The heater pads (pins 4 and 5) of the left 6FQ/CG7 and 6EJ7 need to be
tied together with a twisted pair of wire (to reduce hum). Same for the right.
Each will go to their respective power supply leads on the ST-70 power supply.
The image below shows this, as well as the bias connection we talked
about earlier.
Note for Advanced Builders: You can use a pair of 3EJ7 for the input tubes
and wire their heaters in series. Tie the now 6V string to either channel.
To aid builders with the pad-number-to-wire arrangement, here is the
original Dynaco ST-70 schematic:
View attachment 830909View attachment 830906 View attachment 830909
Pad numbers "3" and "18" are not used on this board and the 18K/2W
resistor may be added externally to the preamp power sockets, if desired.
Pad number "19" is labeled "B+1" on the DynaMull board and pad number
"20" is labeled "B+2".
The power supply of the original ST-70 requires two resistor changes:
If you are using our ST-70 power supply board, use the components
shown, 47K, 2W and 4.7K for R9 and R10 on that board, respectively.
If you have a different B+ off point "C" than the stock Dynaco due to the
use of
use of solid state rectification or a different power transformer, please adjust the
4.7K resistor so the B+2 is in the area of 415V to 420V.View attachment 830906
