J RR
Hey all!
I have an ST-70 I've been trying to restore for a bit now. Replaced the board, and got a new can cap in. Also redid the output connectors, and replaced the selenium with a diode.
Problem: fuses blowing. Before it kept blowing fuses, the power transformer would vibrate a whole lot. Also looked like the rectifier was a bit of a runaway, and I was able to test the amp, but it sorely lacked power.
I believe everything I put in should be fine, as long as I read the schematics right. So I'm a bit confused about the blowing fuses ... also, the fuses blow when no rectifier tube is in.
Any help in this would really rock ... because I'm tryin to kick it with this amp!
