Hello Dave,
Aside from ensuring that the 47K's matched up I did a test where I took a THD at 20KHZ both with and without the o-scope connected to the .1 MFD capacitors.
The THD was remarkably higher with the Oscope connected which leads me to believe that the scope may be playing a part in what im seeing. This is somewhat of a paradox as the
measurement device is ruining the measurement under test. I should mention now that for the THD tests Ive posted, none of them had the probes connected to the .1uf capacitors and
therefore didn't ruin the results.
Youve noticed that im only testing one channel. I agree both should be under load to represent a more accurate real life measurement. There are two reasons:
1. My 47K's are quite mismatched on the right channel (yes this would stop me from measuring, but not for putting under load
2. And this is the big issue : running at 24WATTS ive noticed, especially at low frequencies, that the bias doesnt hold, it drops. I give the AMP a rest between frequencies to collect itself
but find that im making adjustments at almost each interval. Ive seen selenium rectifiers die, but never saw them exhibit this. I can only surmise one of two things.
A) The power transformer cant handle the load after all these years
B) My isolation transformer cannot operate the whole workbench and the AMP tandem.
I will be testing the B possibility tomorrow with an inline voltmeter from mains to the AMP
Be that as it may, in keeping the bias at the right intervals, ive completed testing at 24 Watts, so I have somewhat of a baseline
Note that at 20 hertz the amp output completely falls apart, ive not added 20hz to the chart. Further note that Im running 6GH8A tubes and have heard that there may be an adjustment needed for them
with regard to CAPS and resistors
Though not optimal, the characteristic curve that ive seen in other results says im in the ballpark
Note that 10K to 20K was NOT done logarithmically and changes the look of the chart, giving the top end a linear appearance, i wanted to get more detail on the high end
Here is the conventional chart with a best effort on 20hz with an average of a few samples... but may in fact be total rubbish. all other values are the same as previous but logarithmic
Also, your document on the ST70 is fantastic..
Regards
Jordan
