heavy loading on the power transformer will drop the voltage output on all of the secondaries. Probably not really an effect of the rectifier so much as a limitation of the power supply as a whole.
Also, just a mention but you won't see a steady 1.56 across the cathode resistor when the amplifier is passing signal. You'll get AC+DC on there and it will skew the readings. If you want to see if the bias supply is sagging, you'd have to measure voltage right at the output of the bias supply.
Yes the 1.56 is a product. Im going to be measuring the bias itself independently from the 1.56 test port.
All of the bias testing mentioned had no signal on the input with a shorting plug on the rca jack.
if the test ports change and the bias remains stable, then what im looking at is a change in the total current of the EL34's on the channel.
That being said a current change can be caused by the transformer as well as the GZ34.
Filament voltage, plate voltage etc.
However , even though all transformers drop their output to some degree under load. When the load is gone it should swing back. and not after 10 minutes.... UNLESS... heat is a factor
however less doubtfull than the other possibilities
That being said..........
At constant wall voltage...... with a constant bias........ with a constant AC input on the GZ34.... the transformer cannot be an issue.
This would be the next logical test.
As the curve still has a takeoff with the same characteristics, once this voltage issues is solved
the iphone test will be done again in the exact same way using a 7199 vice 6gh8a
If the curve remains yet the same again, i will assume that the problem lies within the feedback circuit and will make a minute pf adjustment to see if the curve moves. If it does ill proceed from there and find the optimum value.
Also as an afterthought , i want to remeasure the rms voltage going to the el34's after the phase inverter and then flip the probes. at 10k to 20khz If the flipping of the probes matches the flip on the oscope display ill know that it is capacitance or loading in the probes causing the issue. If it does not change ill know that it is in the circuit itself
