I know the output on the ST 1700A tweaks a bit. Its not a huge amount, but I've noticed that I can always see a difference in output when I shift the multiplier. I need to change the level pot on that to a 10-turn to compensate for that. Normally I just ignore it, but it does screw with frequency response tests just a bit.
The level set does only work when you're using it to set the distortion levels, but you can use it as a handy way to watch your zero db point. The actual voltage is not critical. The other way to do it is simply measure your output voltages and record them, then convert it to DB relative to your zero point. I use a spreadsheet to get that done for me and to spit it out into a graph format if I feel the need.
