Im going to take a minute and put the usual conversation of THD, graphs and math aside to make an observation. While I say this, I will still be doing the experiment when the 47K POTS arrive
Id replaced the two 10ohm resistors that read at 16 and 12 and put in my matched 270K's on both channels
Today I disconnected all of my test equipment (except for the multimeter on the 1.56bias)
I replaced the test equipment with my AIWA 8 OHM 3 way test speakers. They are my second favorite when you consider that I can't put my 1.5 meter tall JBL's on the test bench.
I was utterly amazed at the sound produced by this AMP. I didn't need the 331A to tell me how good it was.
3 hours I sampled songs, including a few that I know run the amp to its very limits including
Buddy Rich : birdland and caravan
Freddie Mercury : Exercises in love (a most difficult one to pull off without distortion)
MFSB: manhattan skyline
Ella Fitzgerald and duke Ellington songbook
Dire straits greatest hits (you can hear the pick scraping against the gnarled contours of the E and A strings from the lead guitar)
This AMP is as close to bone stock as it gets, as you all know, right down to the selenium rectifier, save the 6GH8A conversion. It has its own characteristics, and shortcomings,
most notably, the power transformer, and the single GZ34. The power transformer is the single biggest cause of sag
Aside from that, and with the test of the 47K's balanced, there is little more Id like to do to this amp than conduct that last change and test, and close it down.
Once my last test is done I will be moving it into a new SS chassis and replacing the 4 el43 sockets, the power/monostereo switch, and repainting the transformers.
replacing the power transformer with a 120v modern one is still up for debate.
Serenity is knowing the difference between the 'tube sound' and the 'solid state' sound. The difference is.... Every tube AMP is unique and has its own characteristic/harmonics.
No two tube AMPS sound the same, each has its own personality. No gimmick will give an AMP a better tube sound, just a different sound. Its uniqueness is in the mechanics of how different
sounds and harmonics are processed and amplified, nothing more.
J
