I picked up the speakers and got them home. Here is the skinny.
The seller says they are the Excelsior model. From some of the web reading, they appear to be the Esquire. The owner's grandfather knew actor Eddie Bracken (Roy Walley from the Vacation movie). Eddie was a part-owner of Stan White's company, and talked the original owner into purchasing a set. The owner used to drive them with a Sherwood amplifier, and they were built into a bar-like structure.
Each speaker has two 8" mid-woofers and a single 4" (5" ?) tweeter. They look great, much nicer finish than the pictures. The grills used to be white with gold speckles, and are now much darker from picking up all the dust. The speakers used to have conical feet which have gone missing.
The woofers: they have paper cones and are very brittle with broken paper surrounds. The back of each woofer has a round magnet and it's marked W-98 and 270804.
The tweeters: paper cone tweeters inside a simulated wooden horn. Marked W951 and 270752.
The crossover: a single capacitor in front of the tweeter, nothing else. The woofers are not crossed at all. It appears the woofers are wired in series.
The enclosure: back-loaded horn design. The inside of the top of the speaker is rounded and it vents downwards. The back of the speaker is louvered, so there are two exits there. The part of the enclosure I can see is very well made, rounded where it needed to be rounded and square where it needs to be square.
The advertising says the following: curved, not folded, exponential horn (1% of formula). Multiple flare formula (patent applied for). Passive phasing chambers. 21db/octave acoustical crossover. Distributed throat characteristics (not found elsewhere). They were sold by Harvey Electronics and ASCO in New York, alongside of such brands as Fairchild, Dynaco, Ampex Tandberg and Quad.
The model is "The Esquire", originally sold for $194 each.
I have to figure out two things:
- how to fix the drivers, as they don't appear to lend themselves to standard re-foaming due to the brittle paper surrounds.
- how to clean the grill fabric
Does anyone know who made these drivers?
Attaching a few photos as well
