thanks dave. not even one out of 5 in the right sockets is something to keep that seller off the roulette table.
i've only had a few minutes with the amp, being very bummed it arrived with the tubes were broken. it traveled close to 3k miles to get here so luck of the draw. when the bench clears a bit i will look closer now that i have the schematic.
the 2 toasted grey resistors on v2 would be 47k 2w in the acrosound schematic. it looks like maybe a fer of the carbon comps have been changed from the first build. i guess it is time to check the trannies to make sure they are still good with the seller's tube position mix up. hopefully she just plugged them into the wrong sockets for photos but the toasted 2w 47k make me think she plugged it in to line.
assuming the xformers are ok, if you had this amp, would you restore this to the original circuit? also what would have been the original plan for a tone stack? i am assuming that in the original design perhaps that was another module/preamp?
