Stands for the Klipsch Epic CF-4
Alpha Lima
Treading Water
Hello, folks.
I have a pair of the Klipsch Epic CF-4 (version 1). A portrait of them is currently my avatar.
These are big, beautiful sounding speakers - but they have a major flaw, one I'm convinced ultimately doomed the Epic line: the tweeters are placed too darn low, particularly for such a big, heavy speaker.
They must be at ear-level to get the best out of them. However, to do this, the cabinets should have been at least 7 or 8 inches taller to accommodate the driver configuration and those huge Tractrix horns. D'Appolito configurations are particularly prone to roll-off in the upper octaves when you go off-axis vertically.
No wonder they didn't sound at all like traditional Klipsch speakers!
And at 44" high and 108 lbs. each for the CF-4, you can't safely tilt them back like a pair of Cornwalls. These babies need stands (unless you want to listen to them from a beanbag chair).
Which brings me to the point of this thread:
Right now, each of my CF-4s is sitting atop a 12" high wooden footstool, which was originally a way to temporarily get my CF-3 tweeters up to ear level. But this lifts the taller CF-4's tweeters to around 39" above the floor, 3" too high for the optimal seating position on my couch.
What should I do to have 9" high stands that can take the weight and 17"x19" footprint of the CF-4? (No, sawing off the legs of the stools is not an option.)
Also, I have hardwood floors. Would slightly shorter stands on heavy duty casters be recommended? I've seen them on stands for speakers like the B&W Matrix 801.
As usual, your advice and counsel would be most appreciated.
- Alpha Lima
I found some nice small welded steel-frame tables with wood tops at the local Marshall's / TJ Maxx discount clothing store. They carry furniture as well. They were very sturdy underneath my CF4 and raised the tweeter up, which I agree is best.
Why not just tilt the front ends up where they fire more towards your listening position? That's what I do with my CF-3's and works just fine. I'd rather not have mine on stands, personally. I sit about 12 feet from mine and it doesn't take a lot of tilt to get them where they work really good...maybe 3/8" or a tad less.
That tractix horn is made to disperse the sound pretty good, I'm not sure it would benefit being raised. I have CR-3's and CF-2's and have no complaints with their imaging.
Instead of committing to expensive stands, try some cheap temporary stands to hear how they sound. Concrete blocks are available in various colors, heights,2",4", 7", 9", 12" for a dollar or two each. Are non resonant and stable to tipping. Put foam non slip matts or other under and over to protect floor and speakers.
I use them permanently in my cave. Almost same color as carpet. Not WAF.
When not needed, just put out at curb.
