Yep, Luxmen (I guess that's the plural?) of that era certainly look luxurious with the rosewood veneer paired with the alloy front. Their turntables of that era are rather gorgeous, as well. The timber cases on the older Sansuis are nice but more conservative and not in the same luxury class as some of those '70s Luxes, although of course opinions vary (as they should).
I recall seeing an AU-D9 (I think) that sold in Melbourne a year ago that had classy rosewood veneer panelling combined with black fascia, but no doubt the others lurking here can guide you on their suggestions for a timbered Sansui, if that's a key consideration.
You might have inadvertently started a "best looking Sansuis" discussion!
An AU-D9 I did have once, it is definately on par with or beating the Luxman, the only thing I did not like was the already a bit vulnerable build quality and these marketing-hype heatpipe cooling stuff (as a lot of brands including Luxman did during those days).
My daily use one is an AU888, which I totally restored with all new caps, most transistors, all metal film resistors, etc. Plenty of power for the living room
I have a L-309V also, which I restored, it has nicer machining of the knobs etc, compared to the AU888. The L-309V may be a year earlier than the L85V, but it incorporates just about all of the circuitry of the L85V although populated on different circuit cards, TT input circuit is same. Pictures of both resto's are to be found here on AK.
For power, of course it beats the AU888 by a lot, as the AU888 does not meet its power specs in standard form (45W at 8 Ohms) , while the L85V will do (L 309V measures 80 Watts and has very same part number transformer as L85V). The very reason is power sag of the AU888 transformer they skimped on, pulling the supply below +/- 35 Volts under load.. I think just a little more capable transformer alone would lift its power specs, already.
AU888 is much easier to repair and less vulnerable than Luxman, if it ever fails.
(read: amps like the Luxman L85V and Sansui AU-D9 need a better tech, compared to the AU888 having a lot of room, swappable boards and extremely easy access circuits)
So for a woodcase, also consider AU888 and alike types of the era.
I have a Sansui Seven also, which I do NOT recommend because of the pushbutton switches acting up all the time needing some pushes in and out, according a flipper I know most of the old alikes (Six and Eight) suffer from this problem.
Same type of deterioration seems to happen on many Pioneers also, I had SX838 and 929 ones having this problem.
Of course, this is about wearout and not all of them have it, but buying units having had too much deoxit attempts over the years results in buying another ones annoyance piece.....
