okay.. with the VR803 all the way down and boards installed and unit powered on I've got a dim light on the DBT...no shorts.
Okay, which ones are the emitter resistors?
Yep.. i saw that after I re-read it. I've got 450MV across one and 470 MV across the other..
I only fire it up long enough to see if there's voltage (2-3 seconds) and shut it off.. and with the output transistor voltages, i get 1.5 volts on the rear.. and practically zero on the front.. it's actually in the negative by half a volt
Yep good call, with the shutting off after a few seconds......
Not sure what you mean by the front and rear.......I will explain in more detail....
The TO-3 output transistor body, the part which is insulated from the heatsink is the collector, the collector is connected to the socket by the two screws which go through the heatsink and onto the socket.
All you need to do is put the red probe on the transistor body, and the black probe to the chassis...
Im looking for the correct voltage and polarity here, most importantly the polarity.....
If that is correct, get your screwdriver on that bias trimmer and wind it up while looking at the voltage across one of the emitter resistors.....let us know whether it goes up or down.......
What I meant was the transistor closest to the front of the unit, and the one to the back of the unit. And the readings I got are the 1.5 volts and -.5volts
Do you still want me to see if i can adjust bias confirming the practically 0 volt readings?
Edit: I got brave and checked it.. and adjusted it both ways as far as it would go.. and it stayed at the 474 MV reading..so no change
Okay, I got 1.5 volts on the collector of the driver transistor..before taking the outputs out.
I took the outputs out.. and turned it on. I got a dim light.. but I heard a light pop from the driver board.. and some magic smoke. Funny thing though I can't see anything burnt or discolored..and it wasn't enough smoke where I could see exactly where it was coming from.
I've got the other board here, I'll do some checking to see if anything varies from one board to the next.
I did a quick check without desoldering anything and all the values were within several ohms of one another..so maybe i flipped it off soon enough :scratch2:
I checked the driver transistors as well.. and those are okay.
I didn't realize you were at work.. i forget the huge time difference. If you need to get back to work that's totally fine with me.. probably help the both of us if you were in front of yours.
I'll check the outputs again, and see if there's any wires that are touching..etc. It's there.. i just gotta see it!
Thanks again for all your help Kevin!
I found a dead short to ground on the collector of 2sa566.. but not on the channel we were testing. I found that the holes that the screws went through were off a tad.. so i took a drillbit to them.. being careful with the shavings of course. Still had a short, and found a couple cracks in the mica insulator.. I used electrical tape doubled up with the mica in the meantime..took care of it for now....not a permanent solution.
Also, with the channel we were testing I found a really funny reading on the emitter of one of the 2sc893 outputs..With neg. on ground, I get -1,5xx ohms..and it jumps all over the place..seems to actually climb over time. This is with or without the transistor in place. If you're looking at the front of the unit, it's the right side..the front one..a blue wire. It goes to the emitter resistor on the F-1277 board.
