jcmjrt
Addicted Member
Well, I've been reading about people steam cleaning records and mapleshade is selling one so I rolled on down to Walgreens and purchased a Perfection Steam Cleaner. I cleaned a batch of 20+ records about a week ago and have now played through them all. I used the steam cleaner in conjunction with my diy vacuum cleaning. Basically, I cleaned with my normal cleaner/brush, vacuumed, steamcleaned, vacuumed, rinsed and vacuumed. The addition to my normal cleaning routine was the steamclean,vacuum. I used the same deionized water for the steamcleaner as I use in making the cleaner and rinsing.
What do I think? None of the records cleaned this way after playing went into the clean again pile. I fairly often would have a couple that would. One of the hardest parts of the record to get really clean - the first bit of the first track - seems to have been quieter with the steam clean. I did make sure that I put the steam on that bit of the vinyl a little extra. It doesn't seem to have done any damage and at this point seems to have done some good so I'm going to continue with this.
