whoaru99
Epic Member
In the US, modern residential electrical services are typically 200 amps at 240 volts (with the 240V comprised of two seperate 120V lines fed in tandem with a common neutral and earth ground).
Just FYI, the service is not 240V from two separate 120V lines. The service is from a 240V center tapped transformer. 240V is fed to the house and two 120V legs are derived from that to the center tap (neutral).
By rights, it's a 240V split phase service.
