Stereo image abnormalities
Have you heard of the magic triangle? Your seating should match the speaker separation, in this case you should be sitting 8 feet from both left and right speaker. If you have to sit at 11 feet, separate the speakers 11 feet apart. This is a must for imaging and sound stage and should be the main priority in setting up a system.
The next thing I would do is move all your room treatment out of it and bring in things you are going to have in there to make it a comfortable living space. In other words, I don't think your card board boxes are going to be your tables. Get some throw rugs on the floor, plants (Dry or Live), wall hangings and decor. Room treatment is not just industrial acoustic panels thrown all over the place.
Once your actually moved into this space and corrected the flooring and seating then we can see if acoustic panels help judiciously placed. What I see in your photo makes my ears hurt and looks like your putting the cart before the horse.
FWIW: IME the Golden Triangle often leads to the hole in the middle effect. I usually start with a speaker width of 70% of the listening distance..
I’ve done both the equilateral triangle configuration and otherwise and have experienced a strong center image with each...but only in rooms with a deliberate and comprehensive acoustic treatment scenario (all early reflection vectors treated with absorption panels).
I’m curious as to why you have such an extensive acoustic treatment program, but absolutely nothing on the front wall?
I at first though that maybe you were attempting LEDE, but that can’t be the case because you said you have diffusers on the back wall. What type of diffusers are they, by the way?
With regard to the asymmetrical room, alcove and window causing the image shift...I’ve worked with asymmetrical rooms that have windows or glass and openings to other areas/alcoves and have been able to get a strong center image without covering all the glass so long as the early reflection vectors are treated with absorption and all opposing hard surfaces have absorption on at least one of those surfaces to kill the bounce. Your window is (mostly) behind an absorption panel and has the glass covered by fabric...the alcove has an absorption panel in it to attenuate any possible resonance issues and is a good distance away from the listening spot (so any reflections coming from there are late arriving and relatively inert). I think you’ve addressed these potentially problematic areas appropriately.
Your listening spot is fifteen feet from the front wall (wall behind the speakers)
and that puts you almost in the center of the room...not ideal. Try moving the listening spot closer to rear wall by a few feet and also moving the speakers further into the room the same distance....maybe six feet into the room from the front wall for the speakers and seventeen feet for the listening spot (as a starting point). This will get you and the speakers further away from the alcove and reduce interaction with the window by moving the first reflection off of it. Don’t forget to relocate the absorption panels at side wall first reflection locations. This will remove a panel from in front of the window, and though it will no longer be an early reflection vector, I still think it a good idea to cover up the glass as much as possible...so maybe take the panel in the alcove and move it over in front of the glass.
Also, unless you have a few reference recordings you routinely use to test and dial in a system, you need some sort of reliable reference tool. I like this one...
https://www.audiocheck.net/
Michael
Yeah, and I believe symphony orchestras usually put a piano on the left in front of the first violins.
I agree, you both make some valid points.
Hi Howard.
I figured, but made the comment because it's so easy to overlook some issues, make quick checks that can be confusing, and begin working on the wrong thing. Of course, neither you nor I would ever proceed in such a haphazard way. Except that I have a couple times. :)
Good thread; I missed whatever drama may have been posted previously.
I believe the issue was someone making a duplicate post lol.
As for the magic triangle and toe in, I've found many speakers work better aimed straight forward, especially vintage and large speakers. That said, my Infinity Modulus are small and also benefit from facing forward in larger rooms, smaller rooms definitely improve with a bit of toe in.
If I've learned just one thing in this hobby, it's that nothing is cut and dry.
Again, try moving the equipment to the long wall, you'll be amazed at how much larger the soundstage will be, and improves depth.
So that last part is cut and dry...or??? ;)
No it's not, it's whole and wet.
Let's take a room 300' X 400', I don't think it would make any difference, but with the OP's setup I'm fairly certain benefits will be gained.
Fiddle with the balance knob, and start listening to the music instead of trying to pick apart the details. Trust me, you'll enjoy it a lot more :beerchug:
Not all speakers will produce a soundstage no matter the positioning, so no, it's not cut and dry. And just moving to the longer wall without thought of setup could possibly hurt the soundstage, agsin, not cut and dry.
But as the OP mentioned the "soundstage" he was getting seemed mostly locked to the center, but at times drifts to the right, moving to the longer wall should make what he's already getting wider. Do you disagree with this?
I don’t disagree with anything you’ve said, necessarily...but I’ve not found the setting up on the long wall thing to be a cure all. It has its merits, but some are quick to suggest it as the optimum configuration without acknowledging that many times it leads to increased SBIR and also locates the listening spot sufficiently close to the rear wall that it creates a strong early reflection from that location...both or either of which can negate all the benefits of moving the sidewall reflection vectors further away from the listening spot.
There you go. My dedicated listening space was highly tuned with a host of acoustic treatments and after marveling at the results for a few years came across an Acurus preamp that had a balance knob...which I hadn’t had in years...AND the balance could be controlled on the remote. Friggin’ game changer right there.
Hold the phone...no balance control? On a preamp???
Not that I have to use mine often, but I'd feel naked and alone without my tone and balance controls.
Oh for sure. I was once a hard core opponent to tone controls/balance knob on preamps...and could get away with thinking that way since I had the luxury of a dedicated, well tuned and acoustically treated listening space....
But getting control over balance with the Acurus proved to me how powerful and useful that simple feature can be. And now that I’ve been setting up systems in rooms with little to no acoustic treatments, have come to appreciate a good set of tone controls (love my Schiit Loki), as well.
The OP's room is wide enough none of this should be an issue.
All these room treatment Ideas are great but I dont feel the issue of why thing's "shift' over time in the same session has been addressed.
I have previously posted my thoughts but original poster needs to elaborate more or something.
I agree...so long as he gets the speakers off the front wall at least three feet and absorption on the wall directly behind him.
I've found heavy drapes work great, no window required lol. I've even used vertical blinds turned at a 45 degree angle in the past when those were popular.
I just re-read the OP’s comments and missed the part about the shift only happening as a song is fading out. Is this accurate? You only experience the image shift during fade out, HowardMil?
This is my guess: the reflections are frequency dependent, so the effect on the stereo image will depend on what music you're listening to and what its frequency content is at the time. Or maybe the reflections are level dependent, in which case the effect will depend on the volume at which the music is playing. The second guess seems less likely to me.
More generally, if you can't be about the same distance from the speakers as they are from each other, you are better off being closer to the speakers rather than farther away.
Michael
Hi Michael:
Your comments have addressed the issue perfectly!
Now a question or two and some observations.
The left alcove has actually (3) moving blankets HANGING.
I was thinking of buying a STURDY “ small divider” ( http://nymag.com/strategist/article/best-room-dividers.html )to this opening and hanging (professional?? Lol) >> absorption blankets
https://www.vocalboothtogo.com/product/vb-80-group-product/
hanging them over straight down the divider or partition as these blankets have better absorption quality. Question being : does the partition need any requirements regarding material or build quality?
2. You’ve got my right window down to a pat!!!
I’m wanting to order some EVERY DAY blinds ( material or wood? ) OR: should they be some sort of sound absorptive or sound deadening blinds (drapes) . Then either leave them bare with no absorption blanket or test out a blanket on half window; or either or? The first right reflection panel as you said is covering a bit of it.
Should there be a 1st left side reflection blanket behind left drywall 1st. Reflection panel as well?
The back wall has 3 GIK Alpha5 diffusers spread along 14 foot short wall. Along with lots of unopened boxes behind my listening chair. I have those GIK 244 ceiling bass traps midway between me and the speakers/ but ironically- still getting a bit of SLAP ECHO..... I was told that front wall behind speakers is the LAST place to treat if nothing done so far kills a bit more echo (GIK) .
Another irony is that the first thing I put up were the monster bass traps in front ceiling corners- with Range Limiters..... essentially damping bass but leaving mid/ high frequencies absorbed much LESS!!
Lastly- moving speakers out a bit more and listening position as well: a good thought but would that eradicate the alcove-window- image situation? Or to proceed with that as well??
Lots of thoughts here....!
Thanks
Howard
Before you put too much effort into DIY projects, I suggest you experiment with relocating the speakers and listening position since it will take a very small investment of time and resources and produce definite changes.
Along with what I suggested, I also like @rothwellaudio ’s suggestion to create a near field arrangement to remove as much of the room influence as you can (without the chore of setting up on long wall). Leave the speakers more or less where they are, but maybe create an equilateral triangle with 6’ legs. That will put the listening position at roughly 10’ which locates you damn close to a room dimension 1/3...so modal beavior will be less erratic.
And although it may seem like GIK is suggesting that treating the front wall is a low priority item, I can assure you they would not underempahsize it’s influence on a proper acoustic treatment scenario. There’s a lot going on there (acoustically), and my experience is that addressing it appropriately creates improvements that are not negligible...particularly to image resolution and mid/upper bass clarity.
I’m also a little confused by the suggestion that the only bass traps in the room be located at the mid way point on the ceiling when it’s common knowledge that low frequencies accumulate most where boundary surfaces converge (corners).
Are your absorption panels and diffusers hung/mounted or can you move them around easily?
Michael
