linuxslate
Well-Known Member
Also known as the "Compromising My Principles build."
Yes, I'm at it again. Building basic Tube Amps around Switch Mode Power Supplies. The whole purpose of this build is to test the pictured SMPS.
It's a basic P-P stereo power amp based on surplus 6п14п tubes. It is a very low budget build.
Other features (or lack thereof):
1. Note DAC board. This was a DAC that I rejected for my previous build, but I figured I might as well throw it in this build. I don't recommend these or anything based on a PCM2706. It sounds no better than a PC's audio output (Intel HDA), and there are issues with the PC volume control working correctly on both Windows and Linux. So why use it at all? -- It's more useful built into an amp than in a bin under my bench. -- There's already a square hole in the chassis. -- Having a built-in DAC is convenient.
2. The chassis is surplus. That is why it has the cutouts it does. There used to be an LCD display in front. I may order an LED VU meter for it, or I may just leave it out for now. Either way, there will be smoke colored acrylic there. The LED VU meter will be connected to the input, or perhaps between the driver and PI, it won't actually be measuring power output or anything. I'll try to adjust it so that the Red LEDs do reflect onset of saturation/clipping. -- Solid State input of VU meter connected to audio signal -- Principles - Compromised.
3. The long slot on the back panel will have a mesh screen behind it so that it acts an ventilation. The RCA input jacks will be in that area, too.
4. I'm using a tiny toggle switch to select the RCA inputs or the DAC. The input switch will be on the back panel. I don't like passing audio through toggle switches (Principles - Compromised.)
5. It will probably use cathode biasing. (Principles - Compromised.)
6. Hardware and discrete components will be picked during the build, and are not shown.
7. It will have handles on the front, and will overall look very much like a cheaper version of my previous build. I forgot to put the handles in the picture.
8. Both parts and component values are subject to change. (for example the big, ugly toggle switch). If I find a prettier power switch, I'll use it.
I will detail my testing of this SMPS in my "Modern Power" thread. Lot's of people have already provided their comments on using SMPS's in tube amps. I (and probably the moderators) would prefer if we do not do that here. Useful information on SMPS's can go in the other thread.
What is appropriate here (and requested) are comments on the rest of the circuit. Please note that the build is obviously in an early stage. So is the schematic. Many component values are simply based on what I have on hand, and may change as the design progresses.
