I continue to find that this amp circuit matches the ASR-433 schematic that Tom Bavis has on his website. The ASR-433 is labeled as circa 1960 and the ASR-333 as circa 1961. That's what leads me to believe this 333 is an early one. I edited out the mag phono section of the 433 schematic to only show one channel starting at the gain control. This exactly matches this amp. It has the individual gain control flowing into the stereo master volume, then into the tone section and then into the power amp. It also shows the feedback off the 8Ω tap. It all matches. This has the loudness compensation on the master volume but just doesn't have the defeat switch.
Maybe incorrectly, but I am assuming the changes on the later ASR-333 schematic were made as an improvement to the design - either for sound quality, or reliability, or both. With that in mind, I am changing this amp to match the newer schematic. I changed the first power supply dropping resistor from a 1K@2W to 2.2K@5W. I moved the feedback to the 16Ω tap. I'm going through all the resistors in the power amp section, and noticed that R15 is 470K but is 1M on the newer design. I plan to just change all the old carbon resistors in the power amp section as well as the 47pF and .01uF caps. I won't cost much to do, and should be worth the effort.
Once I get the stability issue resolved, I still hope to do some testing and post the results.
As to why the OTs were changed in the first place - I have no clue.
