stromberg carlson console find
fisherlover
stromberg carlson console question
picked up a small very basic model rp-721wo
stromberg carlson tube console
looks like it's a SE type with 7408/6v6 outputs
shes sounds fantastic with even the crappy 6x9 speakers
but i noticed that the amp has no RCA jacks
can RCA jacks, be installed in this amp to use as a standalone like the maggies?
this is my very first stromberg console:yes:
Nifty little console there, fisherlover. No individual speaker enclosures - just one big box - makes for easy access, anyway. The Fisher Electra III I've been working on has 3 compartments accessed from the back, one under the turntable and another tiny enclosure just for one tweeter between the turntable and the speaker panel. I had to desolder the woofers and tweeters just to get the speaker panels off. The woofers fire down through the bottom of the console but being a Fisher it sounds pretty nice as I'm sure you know.
I hardly see any Stromberg-Carlson consoles down this way. Very slick styling - early 60s? Having a console fetish, I'm curious what the S-C nameplate looks like - could you post a picture?
I have a Stromberg-Carlson console amp too. Mine is a P-P 6V6 but is very much like yours. Mine had a 3 pin plug on the chassis that was for the inputs. One pin for left hot, one for right hot and a common ground. I drilled holes and mounted RCA jacks and soldered them to the wires that went to the 3 pin. The 3 pin wires are easily identified by tracing the one pin that goes to the chassis ground and the other 2 will go to each of the 7199 input tubes. I removed the original socket and mounted the power switch in the hole that was left. Hope this helps. Nice find!! Here are some pics of what I did to mine:
I have an S/C amp, too, that I have the caps and parts for that I have to still make into a stand alone amp sometime here soon. It's a little ASR-110 that Tom Bavis helped me with the information on. I bet it will be a great little amp once done. I got the complete console from an estate sale and the gentleman who owned it actually worked for S/C way back when. Pretty cool history on it. It looks pretty similar to the one you have there with a different cabinet design.
ther's no connector at all
the TT signal wires plugged into the tune/pre
nice, it's identical to mine
fill me in on doing the mods
mine was just standing on a curb with snow all over it
luckly the amp didn't get wet:D
the TT pluged into the tuner part
The tuner preamp is plugged into the power amp via a 3 pin connector toward the front of the amp on the top side of the chassis. Look at the pic I posted of mine from the front. The power switch I mounted is in the hole that this connector is in.
I wish I could figure out the magic in S/C amplifiers. I don't know if it's the circuits, tube selections, or what, but I've never heard one I didn't love. I've got an EL84 PP out of a console to do when I get some time. Enjoy yours, Jay
because they were made right here, in rochester,ny
everybody has a kodak camera, right? :-)
thanks,Jay
thank you,
i didn't noticed that before
This is great info - I just found an old SC console today at Goodwill and I believe it has the asr-120 amp in it. I just pulled it and it will be a fun project to convert it fo non-console use - my first foray into tube amp work, so wish me luck!
For some reason mine isn't powering up. I will have to do some checking, but I can't even find my meter right now, lol... What would the most obvious things to check be?
Probably because it was in a console where it was connected to an on/off switch that wasn't located on the amp.
If you look at the schematic, you will be able to tell where to jumper to give it power.
http://www.audiophool.cjb.net/MadeInRoch.html
Looks like jumper pin 6 & 9 on the connector, but last time I was wrong about where to jumper, so get a second opinion!
