I have an Eico ST97; have replaced all the electrolytics and out of spec resistors. Sounds good, has decent selectivity and sensitivity, with decent stereo separation on good stations. I thought that I would touch up the IF alignment and found the secondary slug of the ratio detector transformer won’t move. No sign of damage and I didn’t force anything. Has anyone been able to free up one with heat? Read on the AR forum to heat the slug using a fine tip on a soldering iron and resting it in the adjustment slot, rather than a heat gun that heats the coils and form first.
