I have 2 300rms type r subwoofers in a professionally ported box in my car, hooked up to a digital line converter. But now that I realize that I should switch the stock deck in my car I got a dpx500bt kenwood head unit to replace it. I replaced the head unit myself and it was super easy and breezy because it fit into my dash without an adapter and I just plugged it in to the harness I bought. After installing it, the sub worked great, even better then before (still on the digital line converter) but I wanted to switch it to the subwoofer output coming straight from the deck. Once I plugged the rca from my subwoofer output on my deck into my amp it moves much much less then it did with the digital line converter. Why is it that the pre amp levels coming from my deck are much much less powerful then the ones coming from my dlc, I checked to make sure everything was plugged in right multiple times and I know the sub and amp is wired right because I’ve been bumping them for months before this. I’ve researched it for a couple hours and can’t find anybody with a similar problem so I was hoping someone here could push me in the right direction, thanks
