Hello all. Trying to learn electronics and I have a Sherwood SP-165W, 8 inch subwoofer that I thought I would try to fix. I know the very basics and I have an ESR and a DMM to work with.
Sub has power, but no inputted sound will come out. It just makes a constant, even, pulsing sound (like a motor boat). The sound does not change with volume, it stays exactly the same. I checked the woofer, 7.6 ohms. No visibly damaged components. It is pretty simple, so I am just going through and checking every component. I am measuring capacitors in circuit with the ESR (is that OK?) and I have found 3 so far that are obviously bad and replaced them. No effect.
I will just keep checking every component, it is not a large board, but I thought I'd see if anyone has any input. I've seen this on some Polk 111 subs and it was capacitors.
What do you think? Thanks.
