I recently added a Definitive Pro Sub 800 to give just a little extra boost in the low end. My room is an average size living room with a vaulted ceiling which makes sound set up a challenge on it's own. My set up is a Marantz 2275 / 2 channel receiver running a pair of ELAC Debut 6 2.0 bookshelf speakers. I added an 8 in subwoofer to get a little more bottom end. So far so good. My issue is, I have to use the High Level Inputs and Outputs on the sub since its an older receiver which is okay, but that set up rolls off the bass to my mains. I am running the Subwoofer to Channel 1 in the receiver and then the Main Speakers to the Outputs on the sub. The Elacs can take full power and sound better that way where positioned in the room. An option would be to run the Mains to Channel 1 and the Sub to channel 2. That would be ideal....but I am already using a Russound Speaker selector to run several pairs of small speakers to other rooms (Deck, Dining Room, etc) so I need that Channel 2 for that purpose. Is there an solution that I am missing? I am willing to use a small external mini amp to run power to the speaker selector but I don't know if that will help. Any thoughts?
