how about if I use Ortofon 2M Read? is it compatible with Infinity Black WIdow for :
- tonearm low mass vs cartridge weight
- screw position is it okay?
Thanks
Below is a copy/paste of the spec sheet for the Ortofon 2M Red.
It would appear that the cartridge weight is ok for use on the BW arm. The compliance at 20um/nm is also ok. The only thing I don't know is how wide that body is. Looking at the photos it appears that the upper part of the cartridge body does not extend much wider than the mounting holes. So I say it "might" mount up ok.
If the 2m Red works, so too would a 2m black which has the best most expensive stylus profile of that series.
-Steve
Output voltage at 1000 Hz, 5cm/sec. - 5,5 mV
Channel balance at 1 kHz - 1,5 dB
Channel separation at 1 kHz - 22 dB
Channel separation at 15 kHz - 15 dB
Frequency range at - 3dB - 20-22.000 Hz
Frequency response - 20-20.000 Hz + 3 / - 1 dB
Tracking ability at 315Hz at recommended tracking force - 70 µm
Compliance, dynamic, lateral - 20 µm/mN
Stylus type - Elliptical
Stylus tip radius - r/R 8/18 µm
Tracking force range - 1,6-2,0g (16-20 mN)
Tracking force, recommended - 1,8 g (18 mN)
Tracking angle - 20°
Internal impedance, DC resistance - 1,3 kOhm
Internal inductance - 700 mH
Recommended load resistance - 47 kOhm
Recommended load capacitance - 150-300 pF
Cartridge colour, body/stylus - Black/Red
Cartridge weight - 7,2 g
2M PnP MkII cartridge with integrated headshell weight - 20 g
2M PnP MkII cartridge with integrated headshell length - 52 mm
Replacement stylus unit - 2M Red (interchangeable with
2M Blue and
2M Silver)
