It's not the cartridge mass that matters as much as the cartridge compliance match with the arm effective mass. IIRC the black widow is around 4g effective mass, so your resonance with the 2m red will be around 11-12hz, when you really want it down around 8 or 9. 11hz isn't terrible but it's not great.
so from your opinion, is it recommended or not when I use cartridge Ortofon 2M Red, that specification as follows :
- output voltage: 5.5mV.
- frequency response: 20 ~ 20Hz +3/-1dB.
- tracking force range: 1.6 ~ 2.0g.
- tracking force recommended: 1.8g.
- tracking angle: 20 degrees.
- weight: 7.2g.
- replacement stylus: Orotofon 2M Red Stylus.
obviously, I use Shure M95ED :
SPECIFICATIONS
Frequency Response
20 to 20,000 Hz
Output (at 1,000 Hz)
4.7 mV at 5 cmlsec peak recorded velocity (Output voltage
given for stereo cut record. For mono cut record, output voltage
at both left channel and right channel cartridge terminals
will be 71% of the above figure.)
Channel Separation (minimum)
25 dB at 1 kHz
Channel Balance
Within 2 dB
Tip Tracking Force'
0.75 to 1.5 grams
Total Tone Arm Tracking Force (Destaticizer on record)'
1.25 to 2.0 grams
Force Exerted by Destaticizer
0.5 grams
'See section on tracking force
10
Typical Trackability (in cmlsec peak recorded velocity)
400 Hz-24 cmlsec
1,000 Hz-33 cmlsec at 1 gram tip tracking force
10,000 Hz-19 cmlsec
Inductance
700 millihenries
DC Resistance
1550 ohms
Optimum Load
47,000 ohms resistance in parallel with 200 to 300 picofarads
capacitance per channel. Load resistance can be up to 70,000
ohms with almost no audible change in frequency response.
Total capacitance includes both tone arm wiring and amplifier
input circuit.
Net Weight
6.4 grams
Replacement Styli
M95HUD: N95HEID Stylus, ivory lettering on black nameplate;
distortion-reducing nude hyperelliptical tip, 5 x 38p (.0002 x
,0015 in.); 0.75 to 1.5 grams tip tracking force
M95EDID: N95EDID Stylus, yellow lettering on black nameplate;
nude biradial (elliptical) tip, 5 x 18p (.0002 x ,0007 in.);
