You can use a Rega template as a substitute. The mounting distance for a Rega arm is 222mm while mounting distance for the MMT is 221.7mm
-Matt
Thanks all !! Looks like I have options...also made me aware of an advantage I’ll have... Mounting on a VPI HW-19 mkIII so I can remove the platter/bearing and will be mounted on acrylic tonearm board...easy flat plane to measure across and check for dust cover clearance.
Thanks,Here is how I do it.
View attachment 2034034 View attachment 2034033
That bar is precisely machined with two holes at the exact Center to Center distance that I need. I than find a place along the arc that lets me fit the dust cover without interference.
Do you have a machinist friend?
BillWojo
Here's one of mine.
What you're seeing here, was once a simple HW-19 Jr Table that I bought new in 1996.
That's a 1.00" Thick Sheet of solid Black Acrylic as the Plinth, and under that Sheet is a 10lb SS Sub Chassis Plate bonded to it. The Acrylic Sheet was only slightly routed for clearance of the SAMA Motor and Motor Pulley.
And yep, there's a SAMA as well (Stand Alone Motor Assembly) underneath in its 10lb case.
16lb MK-IV Platter, a custom made Arm Mount Base for the AQ PT-9 Arm got rid of that egg shaped hole in the Stock AQ Arm Base Mount, and the custom made one is highly precise, 1/2" taller-thicker than stock, no wobble, holds the arm precisely vertical, and has a Nylon Tipped Allen Locking Screw to allow for VTA Adjustment.
Platter Clamp is 2-part custom, coaster is a BDR Carbon Fiber part, with a custom Stainless Low Profile Puck on top so there was enough clearance with the Dustcover in the down position.
All that weight rests upon 4 Herbies Tall Firm Tenderfeet within the wood base, and the SAMA sits on 4 standard height Tenderfeet. The Table is "Herbie-ized" to death, with engthgrungebuster washers, and discs everywhere throughout. Table sits on 4 Audiopoint Brass Cone Feet and Decoupler Discs. and also are Herbi-Ized" with DB Neuralizer Discs.
Isolation Base the Table sits upon is a Silent Running Audio Iso-Base V-3.0 custom made-tailored specifically for the HW-19 MK-IV Table. While it doesn't look like it from this particular picture, the SRA Iso Base has the exact same length-width dimensions as the Wood Base.
Platter speed is precisely handled by the VPI SDS.
sounds like you got all the bells and whistlesView attachment 2034179
Here's one of mine.
Good info. Thanks!Also don't forget that as long as you have an accurate measurement of the actual pivot to spindle distance that you mount your arm at, then if you use an arc alignment template generated using your actual P to S measurement your null points will be good for your chosen alignment (Baerwald, Loefgren B, Stevenson), so I'd say for that arm as long as you have the P to S within 2-3mm of the recommended 222mm you should be fine.
