Fixed a few errors (including a couple from the original schematic).
The Eico is a bit odd in that every input, both low and high level, has a discrete position on the main selector wafer. Every other tube preamp I've seen with a tape head input feeds the low-level gain stage through a single position on the main wafer. The HF-85 actually feeds the low-level gain stage back through a separate contact strip on the low-level input wafer, then out to the main selector wafer. It's rather less elegant than the way Heathkit and Harmon-Kardon approached the problem, but it makes for a far more versatile unit.
