I have a Fisher 500C that I have been using for about 8 months and it has performed well. I also had a Fisher 400C that I used for a short timebefore I got the 500C. I like the extra power of the 500C with my Large Advents. The 400C did not have the capacitors replaced, like the 500C (both had Silicon rectfiers), and occasionally the volume would drop on one channel. I got an Eico Tube tester and have tested the 12AX7s. On the 400c the 12 AX7s, all Fisher (made in USA), test at 880. On the 500c most of the 12AX7s are like the one pictured (a couple are Fisher, Baldwin, Sylvania made in (W)/Germany) and all test 960-980. Should I swap out the unbranded 500C tubes for Fisher tubes? Can anyone ID the tube pictured? And will I have any problem with the difference in results if I do swap some of the tubes?
