Switch lever repair
richardpp
Well-Known Member
Hi, I thought I would share some photos from a earlier restoration in which I had to the repair some switch levers that had been cut short. I hope useful for anyone wanting to replace or repair a broken or bent lever arm, or a sheared pivot pin on an Alps lever switch.
not just the missing knobs
removing the switches
removing the contacts
I used a fine punch to drive the pivot pin from the housing
replacing the stop cushion
Over 50 years, the grease has hardened and stop cushion disintegrated
The cushion was replaced with a piece of soft flexible PVC tubing, 5mm O.D. x 3mm I.D., slit diagonally across its length then fed onto the stop.
It makes the switch quieter, prevents over-travel and wear and is durable. It can also be fitted with the lever in situ.
Lastly
If the pin can’t be reused for any reason then it’s possible to make a new pin out of 2.5mm brass rod. Cut a shoulder, insert and peen both ends.
once restored, the switch should feel smooth and balanced. They are a small, but wonderful, example of fine mechanical engineering.
That is a phenomenal pictorial on the proper tear down and restoration of these switches. Seeing how these right angle lever/toggle type switches were made, this brings home just how much quality of feel was lost when Sansui abandoned their use about 1980, starting with the AU-X1, and began using exclusively push and rotary switches from that point onward. Their use on the professional and definition series line lent those models a particularly satisfying and solid feel in operation.
This type of switch had far superior tactile properties, and just exuded quality that isn't found with other more common and less costly types. And to think that at one time nearly all the Japanese majors made extensive use of these in their tuners, amps and receivers. Then about 1979-1980, they were phased out entirely.
I do wonder if it was forced on them by the supplier (most often being Alps) choosing to discontinue their manufacture, or if they had just become too costly to justify their continued use in new designs. Either way, it was a loss to the overall quality of the human interface factor.
I've also wondered if these switches were dropped because the original tooling used in their manufacture was near EOL after many millions of such switches being produced during the 1970's, and it was decided not to incur the cost of replacing it all. I would love to know, as they went away quite abruptly.
Thanks @DB-7, that's very kind. If I had just one switch to repair I may have looked for a replacement instead. On the upside, all the switches are now working beautifully although I still need to find some original knobs. As you know they're rare as hen's teeth, especially the silver ones.
This is absolutely amazing! Your work is a labor of love. Do you want to start doing a switch repair gig? Not sure the labor involved would be worth it. Get job in keeping vintage stuff alive!
That really is incredible.
How did you weld the new steel to the old levers? Any particular welding gear you used? I've never welded anything in my life but I have a broken switch lever
Interesting question on the demise of these switches. It's likely it was a combination of reasons. Another one to consider is the rise in value of the Japanese yen around this time and the declining market for high end electronics. Higher cost and lower demand is a big reason for the overall decline in quality in the early to mid 80s.
- Pete
