switching power supply help needed
ok, back to this. Some voltage readings for your pleasure. All readings taken with a Simpson 260 series 5.
+ to - on the main line bridge rectifier: 330v
pin 7 to pin 12 on the TL494: 0v
so this tells me I have supply issues to the main switch controller. Time to dig deeper here.
I worked on a LOT of VCR's in the 90's. This is what I've learned about SMPS's. Jon said part of it:
--snip--To work on them, I'd strongly recommend:
An isolation transformer. Much of the circuit is hot and you may need to attach grounded equipment.
A scope. The signals are switching signals and you may have to probe the controller IC (if fitted), or discreet components.
A Schematic. There are many flavors of switching supplies. I've never found any two alike. Similar? yes. The same? no.--snip--
It's also really nice to have a variac. And, when you think you've finally replaced that last bad component... keep looking! Because, when you plug it in, it will be that stinkin' overlooked 220 ohm resistor that has opened to 220K; or that sorta-leaky diode; that takes out 6 of the 12 components you replaced! :grumpy:
Good luck in your efforts.
Brian
ok, so this is what I found so far. This box has a TOP222Y device that apparently drives a flyback power supply. The circuit is virtually identical to the one in this datasheet:
http://html.alldatasheet.com/html-pdf/110101/POWERINT/TOP222Y/384/1/TOP222Y.html
I get ~330vdc from D to S on the device, and about 2 volts from D to C. I get zero volts output from the output side of the supply, but the transformer does ring out OK with the ohm meter. I replaced all of the caps in that part of the circuit with no change. The diodes check OK as best I can easily check them. At this point I'm suspecting the TOP222Y device has pooped out, which is causing the flyback supply to do zilch. The output from that flyback powers the rest of the circuitry inside the device. I have no idea how to test the TOP222Y, so I guess I'll try replacing it to see what happens.
I don't have an iso trans, but I do have a variac. Somewhere around here I had a couple of similar power transformers that I could cobble back to back for an iso if needed.
It can't hurt to try replacing that chip. I guess that is the startup supply. Kind of weird, since the 494 is present. You really should request the schematic from B&K. There is a form you fill out on their website. That would give me a much better picture of what is going on.
OK, so back to this POC. I got the schematic, which should be attatched below. I replaced the TOP222Y since it was under $2 and I was ordering parts anyway. No change that I can see, it still won't light up or kick the fan on or any of that.
Ok, now we can troubleshoot for real. The first thing to get straight, The ground shaped like a triangle, made of lines, lets call hot ground, because it connects to the AC mains. Until I tell you otherwise, make all measurements with respect to Hot ground. when you use a scope, you must plug the supply into an isolation transformer.
With the DMM, measure the voltage on the + side of C15.
Really! Nothing like the correct schematic and having it all there on one page!
Now, if you'll do me a favor and refer to everything by component marking (C15, for instance) I can follow along at home with the supplied pdf, as well.
Earlier you mentioned that you found 2 puffy caps, and the 4 large ones for the rectified AC line current also looked a little swollen so I replaced those too.. Giving the component numbers would you tell me (us) which caps those were?
Thanks,
Brian
Thanks,
Brian
That would be the 4 caps near and including C15.
ok, the story with part numbers.
turned it on one day and it just didn't work. Was working fine previously. Opened it up, and found C40 and C41 obviously puffy and leaky out of the tops. C14, C15, C16 and C17 were also questionable looking, along with C78 (this unit does not have C77 or C79). I replaced all of the caps with same value, voltage, and physical size parts with no change. I then started playing with the aux supply components around TR1 and U4. I have replaced C19,C21 and C22 with same value parts, and C20 was replaced with a 330uf because thats what I had available. All of the diodes wired to TR1 check OK on my rather basic DMM diode check function. The BR1 bridge rectifier also checks fine. If you give me a couple mins I will go out in the shop and get voltage readings across R5 and R6, and across the pair of those so you have the HVDC voltages.
I do not have an isolation transformer, so I can't get you scope readings from anything that would require that.
165vdc across r6 (250v scale)
165 across r5 (250v scale)
340 across r5+r6 (measured, 1000v scale on the meter)
meter is only about 40 years old, so theres no chance it could be off a bit :)
All good. So our HV supply is good.
What do you read on the cathode of D4 (the line)?
Well heres my 2 cents, as someone who has worked on a lot of car audio and tv's which all the new ones use switching supplys, the 494 is a common chip and they do fail all the time, you should have b-plus on the transformer, if not probably has a fuse resistor burnt, the chip is cheep, I think less than a dollar so would be worth replacing, also there usually is some sort of feedback to the chip like a opto coupler which also fails all the time, I would replace that also.
D4 OK, open one way, 0.6v drop the other way
R9 14.7 ohms out of circuit
TR1,
1.6 ohms primary
0.3 ohms D4 secondary
0.3 ohms D2 secondary
0.3 ohms DM PS+ secondary
TR1 measured off the board.
I did replace U4 yesterday with no change. I have another new one that I can try if you think that would help any.
DM+ and DM- appear to feed to the digital volt and ammeter display on the front panel. This also doesn't light up.
Just for yucks, I unplugged the connector from DM+/- to the display. No change in voltage at D4, and the fan and such doesn't run.
