switching power supply help needed
Now you need a scope.
I think that was about where I was at, too.
But, 10 years out of professional electronics repair now, I don't know if I have the ability to ask the right questions and properly analysis the answers on this type of equipment to continue.
Unless it was already mentioned you might ohm out that VCC line (C20 to ground) to see if there is anything close to a dead short on it that would hamper future efforts.
I think you're going to need an isolation transformer to use that scope, gadget. Good luck from here!
Brian
I found a pair of filament transformers that I can get 120vac from if I wire them back to back. Should serve well enough for this.
After you put your transformer together, look at the D pin on U4, with the scope on 50V / div. Leave it connected and turn the supply on. Any activity on the scope or does it just go to 180V and stay there? Then look at pin C of U4, with the scope on 20V / div. Does it ramp quickly up to some voltage and then discharge slower? Reduce the scope to 1V/div if you don't see anything at 20V / div.
I'll mess with this tomorrow, or when I feel less crappy. Got a lovely chest / head cold at the moment and I don't really feel safe sticking my fingers into anything energized at the moment.
goes to ~200 and holds. no other activity.
goes to about 2v and holds steady. no discharge.
U4 might be bad or a counterfeit part. Try another one and exercise anti static precautions when you install it; use an antistatic wrist strap, connected to ground, solder the S, then D then C last. If you don't have an anti static wrist strap, make one with some wire and a 1M resistor in series with ground, to protect you from accidental electrocution.
re-install the original, or the extra new replacement that I have? I bought it from digikey, so I'd hope that they didn't send me fake BS parts. Bag it came it says its made by Power Integrations. Same logo as the original, though all the printing is smaller on the replacement part than the original.
Actually, let's check a couple things before replacing U4. According to the datasheet:
http://www.powerint.com/sites/default/files/product-docs/top221-227.pdf
The device won't turn on until you get 5.7V on the control line. You are only seeing 2V so it never starts. Either something is pulling the output of the transformer down, or the transformer is bad. Check ZD1 D4 and Q3.
If those are ok, remove D2 and see if U4 pin D starts switching when you turn it on. If that doesn't work, see if there is a connector for DM+ and DM- and unplug it, and try again. We are trying to remove the load to see why you aren't getting enough voltage to turn the switcher on.
If none of the above work, try connecting 6V via a battery from U4 pin C to ground. and if that doesn't work, replace U4 with your spare.
this is like a Swedish movie. I have no idea what your all talking about, but I can't wait to see what happens next.
All parts checked out OK. I was able to make the supply run by connecting a 9v batt with a 100 ohm in series from HVDC - and touching it quickly to the C terminal of U4. The fan started and the supply ran with the battery removed, so it seems there is some sort of kick-start circuit thats not kick starting. I wasn't able to load test the supply since my iso trans rig is current limited to about a quarter amp but the display lit up normally and I was able to dial the output voltage from 2.8v to 15.5, which is what it normally did.
So I guess I'm not the only one stumped? :) I'm going to try isolating all of the stuff on the VCC circuit from that winding on the flyback supply to see if its a load issue. If it kicks off on it's own with that pulled, I'll replace the other couple of caps in the unit and see if that does anything useful.
Sorry I missed your post yesterday. Yes, that's what I was going to suggest. Either something is loading the output of the transformer down, or the transformer is bad.
I did some testing to isolate various circuits with no luck. First I isolated the entire VCC circuit by lifting D2 and C102. No change. I then lifted everything drawing from the HDV citcuit other than U4 and TR1 with no change. I kick started the supply with a 9v battery again and put some load on it. I was able to load it down to 20 amps without any trouble at all, so I'm pretty sure all of the output circuitry is good. Its just something in the startup circuit thats b0rked. Is there any chance that its something as odd as the wrong type of capacitors? I selected the replacements to match the original rating, voltage, and physical size. C14-17 are these:
http://search.digikey.com/scripts/DkSearch/dksus.dll?x=0&y=0&lang=en&site=us&KeyWords=P11618-ND
C40-41 are these:
http://search.digikey.com/scripts/DkSearch/dksus.dll?vendor=0&keywords=P5917-ND
C78 is this:
http://search.digikey.com/scripts/D...&lang=en&site=us&keywords=565-1974-ND&x=0&y=0
I'm getting really close to rigging this with a 9v battery holder and a momentary pushbutton fitted through the side. I hate to resort to such butcher work but I'm starting to want this thing working more than I care to piddle with it.
Lovin' the battery thing! :yes:
Samsung made a bunch of VCR's for RCA in the mid 90's. I can come up with at least a couple of models where they would operate fine until the customer's power went out. When power was restored the VCR would present as dead.
It all came down to (if memory serves) a bad 1uF cap. Replace that and it would start up on its own again. The cap could have failed years ago but wasn't a problem until power went out the first time. Then, the cap could no longer restart the supply.
Look for something like that or a ~ quarter of a megohm resistor that incorrectly measures around ~ three quarters of a megohm.
Great help you're getting here! :yes: Sounds like you're on it. Good luck.
good thought on checking the resistor values. I haven't checked them, so its as good a guess as anything else.
