jahmadeus
Hello all,
I recently acquired an SX-1010 in fairly good condition from a friend who is upgrading their system. My friend was the original owner of the unit and said it has never displayed any problems. Serial number indicates it was manufactured in November of 1974.
Visually inspected the unit, everything looked good, power supply board looks a little toasty as others have reported but overall not too bad. Tested the unit, all functions working, controls not too dirty, speaker A and FM indicator lights are out. Sounds very nice as is.
I have done some research on this forum into what others have done with this unit and had some questions.
I've noticed it's common to replace most of the transistors in the unit while rebuilding, with most being modern substitutes instead of the original part. Is it recommended to take this type of shotgun approach if the unit isn't displaying any obvious symptoms? And is the use of modern substitutes due to lack of easy availability of the original parts or because they offer a worthwhile improvement over the original?
Second, I have noticed that there is a redesigned blank power supply PCB for sale which appears to be designed by an AK user. I would love to get some opinions on if this is preferable to just rebuilding/tweaking the stock board.
Any advice is greatly appreciated.
