merlynski
Curmudgeon Electronicist
I am in the midst of rebuilding the Protection circuit and discovered I didn't order replacements for Q5, 2SA733; and Q3 & Q4, 2SC945. None of the lists I have downloaded suggest replacing these 3 transistors. Is this because they do not have a history of problems or failure?
I have replaced all the other transistors and the e-caps, including film for C1 & C2, and the relay.
I did find replacements suggestions in an older SX-1010 thread, which has the same protection circuit architecture:
2SA733 => KSA733, the KSA733 is end of life on Mouser, listed obsolete,
2SC945 => 2SD1616A,
neither of which I have on hand.
I found a newer SX-1050 post with these suggested replacements:
2SA733 => KSA992FBU,
2SC945A 512 => KSC1845FTA,
both of which I have on hand.
So my question is: Don't bother with them, order the older replacements, or use what I have?
Thanks for your inputs!
2SC945 => 2SD1616A,
