Ron Pilgrim
Well, whadya say, Pilgrim
Sorry to hear about your loss. Congrats on the 2100 tho, good choice. What abut the 7080? That things a powerhouse too!!
Yeah he was a lot of help. I learned a lot.
Now I'm listening to this receiver and wondering if I should re & re the other amp board the same way just because I'm thinking that I'm hearing the bass is stronger on one side than the other.
I think Mark said it wouldn't affect the sound at all if I left the other amp board stock.
I wonder if I'm getting a touch of OCD or if in fact there is a possible performance difference?
SX-1080 Recap List
Hi Mark!
Per our PM's and posts, here is the recap list for all electrolytic capacitors.
I have this in an Excel spreadsheet that is a lot easier to manage, but it I can't upload that and the Word.doc is still too big, so I had to convert it to a PDF to upload it. I can email you the Excel spreadsheet if you would rather work from that. Or I can send it in Word.
I was on Digi-key and Mousers' websites because I've noticed in other threads about recapping that people have ordered new caps from both companies. Note I have included columns for replacement model numbers, voltage and uF values, and quantities. I show the model number column as Digi-Key and Mouser because I don't know what company I'll be buying from?
I got a bit overwhelmed by their filters for selecting caps. Maybe I'm showing my noobieness here but from what I see it looks like I have to work with Aluminum Electrolytic Capacitors because that seems to be the class of cap that has the most choices? Some of the things they ask for are above my head but I think I only have the basics covered:
1) Capacitance - check.
2) Tolerance - I don't know what to select here.
3) Voltage Rating - check.
4) ESR - ??
5) Operating Temperature Range - ??
6) Termination - I believe I need to select "leads"?
7) Dimensions - ??
8) Product - Mouser's site asks for a selection with a range of options like: aluminum, bipolar/non-polar, computer grade, general purpose, high frequency, high temp, low esr, low impedance, low leakage etc. I'm not sure what to ask for.
I think you said you were going to send me a list of replacements? That would be awesome. Or if you could guide me in what to select in the options I show above that would be great too.
Pics attached are of the tone control assembly pulled out ready to go. I think when I get the caps I will do it first, then pull the next assembly and do it, and so on. The power amplifier assemblies ( AWH-071 ) look like a bear to get at. It would appear replacing the caps on them and getting those big ACH-085 by the power transformer look like major surgery. Am I wrong?
Speaking if the AWH-071 assemblies - it looks like there two of them. My manual shows a parts list for it but if there are two should I be doubling up on the caps they show?
Cheers!
my choices of ("rules of thumb") Nichicon upw (or equivalent Panasonic) and low leakage Nichicon ukl are well documented, and film caps for what will fit at 2uf and below.
