Results of tests of Output Transistors
I only checked the output transistors that are attached to this repaired AWH-071 board. I did not check the ones attached to the good AWH-071 on the other end of the heat sink.
I didn't de-solder them and remove them from the heat sink - I did this with them still mounted. I attached the leads to the pins sticking up from the foil side of the board. They are clearly labelled BCE etc.
Using my mulitimeter on Diode Test mode and using your format from your post # 11 of 09-08-2005 from that thread you pointed me to about testing transistors here are the measurements:
First the PNP 2SB701 Transistors:
Top One:
black lead to base, red lead to collector, result = .565
black lead to base, red lead to emitter, result = .622
red lead to base, black lead to collector, result = OL
red lead to base, black lead to emitter, result = OL
black lead to emitter, red lead to collector, result = OL
red lead to emitter, black lead to collector, result = OL
Bottom One:
black lead to base, red lead to collector, result = .560
black lead to base, red lead to emitter, result = .616
Next the NPN 2SD737 :
Top One:
black lead to base, red lead to collector, result = OL
black lead to base, red lead to emitter, result = OL
red lead to base, black lead to collector, result = .600
red lead to base, black lead to emitter, result = .635
Bottom One:
red lead to base, black lead to collector, result = .598
TAG! You're IT!
