MIJ_Pioneer
A little side note, I've been using a JIS screwdriver (I love it) for all my Pioneer servicing. I originally purchased it for service on a Kawasaki motorcycle that has all JIS screws, which the previous owner reminded me what happens if you use a standard phillips head screwdriver on. Lots of rounded screw heads. Using this type of screwdriver on this Pioneer gear fits like a glove, I have yet to skip a beat turning any screws. I haven't really seen it mentioned here.
The only difference between a standard phillips and a JIS head is the JIS isn't as pointed. If you do not have one, I suggest you pick one up. The one I am recommending is excellent, it is my go to all the time. If you notice some screw heads have a small dot near the female phillips head. That signifies (from what I understand) a JIS screw. Some do not have this however depending on their size.
Screwdriver: https://www.amazon.com/gp/product/B000W9FN92
More info on the topic: http://rtstools.com/jis-vs-phillips-screwdrivers-and-where-to-buy-a-jis-screwdriver/
Nothing wrong with that. That's neat, you are painting the covers? I'd like to see how that turns out, lets see some photos
Mine are tarnished a bit, looks like someone had used a polish or something on mine and I can see waves/indications of a towel wiped across it from many moons ago.
Did you place any Mouser order yet? Only been able to verify the Power section, but so far so good. I'd recomend to grab ring terminals too (at least 8, grab some extras): https://www.mouser.com/ProductDetail/538-19203-0099
Thanks for the photos! Glad to see it was done right, great idea using a ring terminal on them. I might order some and update the film caps with them. The filter caps include screws+washers but the ring terminals are a smaller diameter on the original filter caps. Still could have cut the factory ones into a spade connector if I didn't have the terminals. These are the ones I used (#10): https://www.mouser.com/ProductDetail/538-19203-0099
Looking good. You are way ahead of me. I got side tracked cleaning up and painting the shield covers for the tuner drum, tuner and equalizer board. They were a mess. Thanks for the pictures. It helps seeing the work in progress.
Nice work... yes the bypass caps go across each main filter cap. The SX1250 (I have found - and the whole line of SX-xx50) are service friendly.
Your filter caps should come with the necessary hardware. Keep up the good work.
