mslupczynski
My 1280 has has not been sounding the same lately. So I decided, as a start, to simply check the DC offset at the output terminals. To my surprise, cold, the L channel is 93mV and the R channel is over 115mV. Both drop when the unit gets warm but are still hovering at L channel 75mV and over 90mV for the R channel after 30 minutes. The unit seems to work fine and other than sounding bad and getting pretty warm just above the power supply, pretty warm all over actually. It seems to be in good shape.
Internal inspection shows that the unit has been worked on a little bit before, some caps replaced on the protection board and I can see where both the power supply board and protection board has had some terminals re-soldered because they were disconnected and the boards possibly removed. The work looks fine so I have no suspicions there. Some of the caps all boards are clearly still original, but I haven't really looked closely at any board transistors to see if any were replaced. I suspect some known problem transistors have, but I'll dig into that later.
In the next day or so I'm going to use the schematic and SM I have and check all voltages at the power supply, the heart of the unit. For those of you who follow standard diagnostic procedure, and general methodical process of elimination, I'd like to know where should I first focus my attention on a DC offset issue like this. I don't want to go in and just start replacing stuff, it doesn't end well. Don't ask me how I know.
Thank you in advance.
