Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
well reading it charitably, since the Pioneer output transistors DO have 4 leads, the verbal shorthand is somewhat forgivable, although his work for the audio company was probably in the night maintenance section, sounds like some "resume inflation" going on.
AND I would beware his "chips", and INSIST on close up pictures of each and every one to INSURE that they are NOT USED at his exorbitant prices.
Craigslist... :nono: can damn near claim anything - caveat emptor SQUARED
out of curiousity.. how does one destroy those original output transistors, at 270 watts per channel, I reckon the speakers will die first before the amp does.
I may not understand the answer, but I will ask the question anyways, the original output transistors had 4 legs, whereas the new one had 3, where was the 4th one derived from ?
Not sure about 1980 but my 980 has the same transistor layout. In my SX-980, only ONE collector connection is used. Both collector pins are the same thing.
Yes.....AFAICT........only one collector is used on the 1980 too. Check the SM. The remaining sequencing is EBC......the substitutes(On-Semi MJL4281A) are BCE..............it would be cool if they could've been sub'ed in without a slight mod.
