Well, the +/-34V pass trannies run warm, not hot, with the dinky little heatsinks they already have. And the plan is, with this board, to move the +/-80V transistors to the large output heatsinks. This leaves the 8V and the 13V heatsinks.
I believe the plan is to use these heatsinks for the 8V and 13V pass transistors, though we might want to check with turbo on that. And although it isn't mentioned, I'd strongly suggest dropping a bit more voltage to the 13V regulator by changing R202 from a 3.3 ohm 1/2W resistor to a 22 ohm 3W resistor, and mounting the resistor a respectful distance away from Q203 so that the additional heat isn't added to the transistors' battle.
Post #27 in this thread has a pic of a completely modded 'stock' board. Current sources, 80V trannies moved to the big sinks, new heatsinks for the 8V and 13V trannies, radial caps for C204 and C205, and the 22 ohm 3W resistor for R202. The end result is much more 'open' and airflow is improved mightily over the bone-stock setup.
The fly in the ointment, as it were, is Molex discontinuing the nifty TO-220 sockets I was using. I liked having a very quick way of disconnecting these transistors without unbolting them, should the PC board need attention. I've recently found the Molex part #22-02-7033 (Mouser #538-22-02-7033), but I've yet to sample one to check its suitability.
I don't think you should rush this to the board house yet, let's let the idea sit and percolate a bit - I myself have many issues tugging at me, even though I consider this an important issue to address.
I need to sit down, with my spare awr-154 board and THINK of all the hassles they have hit me with over the years. We've covered quite a few, and for example you surprised me with the 3.3 ohm 20w resistor (which I haven't followed up on yet either) being available.
Like, what about all the other to-220 transistors on the board that are series pass regulators, what is the intent for cooling them?
It's a heck of a lot easier to correct computer files and paper designs, than deal with the tears that come with spending $$ on immutable hard assets.
I've been through this before, and I DO acknowledge the saying "shoot the engineers and just SHIP the damn thing!!"...
Engineering innovation is fun, but it is more about getting all the pertinent and applicable details under control.
I have most of this design captured in ltspice, if it is of any use. It will calculate everything that one would need to know electrically. It is not thermal modeling however.
I like the fact that this is the first Pioneer pcb re-design that I am aware of.
If it was my design, it would include short circuit current limiting, not by means of a fuse or a fusible link = smoke. Even OVP on the tuner supplies is doable too. I think we have heard of some PAxxxx chips being fried because of a OV fault on the PS. Replace secondary regulators with newer IC's which also have limiting characteristics.
But that a choice of the designer/team and not mine to make.
I can offer to review the gerber/drill fab data and I guess I could do some sim if it is necessary. But it is some simple algebra to get the numbers you need to work with. Not sure if you want to publicly release this fab data, so we can hook up offline if you wish for my review.
Not too sure about the KK conn 22-02-7033 use for TO-220 leads which are more flatter than a 25mil sq post, got to give it a try and test for contact R. I guess you could solder 25mil sq posts to the TO-220 leads as a hack.
What connector?We put the connector on the board for the 80V's rather than on the part. Do you see any downside to this?
No way I'd be fooling with soldering posts into the transistor. Way too hackish.Not too sure about the KK conn 22-02-7033 use for TO-220 leads which are more flatter than a 25mil sq post, got to give it a try and test for contact R. I guess you could solder 25mil sq posts to the TO-220 leads as a hack.
But, for grins, I checked a 3-pin computer fan, and the connector has 2.54mm spacing and the one I had here grips the transistor lead nicely. So...order a 12" computer fan extension (or some such) and clip off any unneeded wire (the wires length needed to move the 80V transistors is 11").
What connector?
That part I got. I was asking what connector you had planned to use. If it is one where the wires are removed individually, I'd prefer to solder the wires to the board and use some sort of 3-pin connector at the transistor, such as the computer fan connector I mentioned in the last post.Q210 and Q211 are actually connectors.
The plan was to have wires soldered directly to the transistors and then plug them into the board.
Ahhh...I C. You'd have to 'train' the wires with a bit of a bend, but clearance for the connector is not an issue.
But...
The real concern is that, if the wires are soldered to the transistor, then replacing the transistor gets to be a real tedious PITA (solder, shrinkwrap, rinse, repeat) if the only removable connection is at the PC board. And having a connector at the transistor AND the PC board is adding yet another mechanical interface. Best to use one connector at the transistor and solder the wires to the PC board.
Guess I should have been clearer about these two resistors...3. Removed R102 and R308.
