I will add to this thread that I had my fun today with tuning up a 1980 FM section. I know someone was in there before me monkeying around.
I noticed that the FM FE mosfet was changed, they did a bad job and lifted traces.
This RF FE can has four screws on the top, but also has two grounding tabs to the pcb which is a PITA. This one was not too bad so I left it alone. A way to test is too ground &/or disconnect your antenna input, mute off, run through the dial listening to scratchy noises (headphones). Sometimes if you go back and forth a few times at one spot, you can hear the noise being reduced, as you wear off oxides and make a better ground contact.
Signal meter was reading "3" on the strongest of signals = Monkey
First thing is to zero the quad detector. No RF muting off, tune to white noise, bottom slug accessed from the bottom plate off.
Minor tweek to a trimmer in the RF FE
In the APC adjustments they say to scope and verify that the 100kHz is present, what they fail to mention is what accuracy it should be set for?
I know if it is off, as in my case, the quartz lock will not work correctly. I monitored the 10kHz, 10x scope probe to a HP 8416A frequency counter and adjusted TC1 for 100K +/-10Hz
They say in the manual that the APC X1 is colour matched to the IF filters?
You will never get the 450mV they state, iirc it was a max of 380mVrms as measured on the Tek DPO. I set it back to what it originally was at ~325mVrms
I did not touch L2, maybe that might have peaked it some more.
So once you get VR3,2 adjusted to 6 & 0VDC spec, it works okay, make sure you test at both ends of the dial.
Pretty good tuner, sensitive, seems to be a bit more selective than the 1250, once it is setup properly.
