The AC side is specified, anode by default and cathode explicitly mentioned.
The ac going in the anode will have positive dc at the cathode.(d2,d4,d7, d8)
the ac going in the cathode will have negative dc at the anode.(d3, d5 )
D2 59vac at anode & 76vdc at cathode
D4 59.5vac at anode & 76vdc at cathode
D7 18.8vac at anode & 23vdc at cathode
D8 19vac at anode & 23vdc at cathode
D3 -78vdc at anode & 58.7vac at cathode
D5 -78vdc at anode & 59.2vac at cathode
If you get good DC, about +70v (d2,d4 cathodes) , -70v(d3,d5 anodes) and +20v(d7,d8 cathodes), check the other sides of the three 2.2 ohm resistors (r4, r5, r23) that feed the regulators. This is raw dc, so it can vary quite a bit and still be ok.
r4 9vdc
r5 -55vdc
r23 23vdc (both sides of the resistor) (r23 checked good with 2.6 ohms - in circuit)
what about Q1 & Q2 jfets? you missed that on my post...
(Yes, the Ampslab 2SK30A-Y are on Q1 and Q2)
sometimes these posts are a work in progress where stuff flies back and forth too quick.
I'm off for tonight (1 am here) so if there is more you want to do, figure out why the primary of the big transformer isn't energized, up to disconnecting a wire for the primary and measuring the dc resistance independently of anything else. (Do you mean to disconnect both the brown & white wires for the big transformer and measure resistance across those leads?)
It's the brown wire going to pin 3 of the board with the relay and big caps. check the resistance between pins 3 and 4. (There is continuity between pins 3 & 4 on the Rectifier board, with no discernible resistance. I also checked the wires for continuity and the traces on the Rectifier board - all with good continuity)
The other wire from the transformer may not even go to that board. It may be directly connected to pin 1. (The white wire IS directly connected to pin 1 on the rectifier board, and there is good continuity between that white wire and pin 1 and the corresponding trace on the board) Looking at one here, the pin 3 COULD have come loose, you were soldering that trace (thermal fuse) an inch away and moving the board around too. (I did not solder a new thermal fuse on that board, but did put in new main caps and replaced the 2.2 m ohm resistor, c1, c2, c5 (with ceramic caps) and the caps across pins 7-10-14 of the Rectifier board. Please see attached photos of that replacement. The caps across pins 7-10-14 are Polypropylene Film Caps 0.22uF 250v, Mouser P/N 505-MKP20.22/250/5 Not sure if those might be throwing the power off? I have the old caps if needed for replacement (see 2nd picture)
