SolutionRoom
I went ahead and re-checked all the voltages (with Pin 22 disconnected). All referenced to chassis ground and VDC. Here are the results:
Pin 1 0
Pin 2 0
Pin 3 0
Pin 4 -9.21
Pin 5 -13.40
Pin 6 -13.40
Pin 7 6.72
Pin 8 6.72
Pin 9 6.72
Pin 10 6.72
Pin 11 5.00
Pin 12 12.3
Pin 13 17.7
Pin 14 -0.395
Pin 15 -0.396
Pin 16 0
Pin 17 0.35
Pin 18 0.37
Pin 19 13.06
Pin 20 -55
Pin 21 0
Pin 22 55
Pin 23 32
Pin 24 -32
Pin 25 -18.1
Pin 26 -13.8
Pin 27 0
D2 anode 51.3vac cathode 61vdc
D4 anode 51.7vac cathode 61vdc
D7 anode 16.4vac cathode 18vdc
D8 anode 16.7vac cathode 18vdc
D3 anode -60vdc cathode 0.67vac
D5 anode -60vdc cathode 0.67vac
R4 63vdc
R5 -63vdc
R23 18.33vdc
Pin 1 0
Pin 2 0
Pin 3 0
Pin 4 -9.21
Pin 5 -13.40
Pin 6 -13.40
Pin 7 6.72
Pin 8 6.72
Pin 9 6.72
Pin 10 6.72
Pin 11 5.00
Pin 12 12.3
Pin 13 17.7
Pin 14 -0.395
Pin 15 -0.396
Pin 16 0
Pin 17 0.35
Pin 18 0.37
Pin 19 13.06
Pin 20 -55
Pin 21 0
Pin 22 55
Pin 23 32
Pin 24 -32
Pin 25 -18.1
Pin 26 -13.8
Pin 27 0
R4 63vdc
R5 -63vdc
R23 18.33vdc
Closest I have are 3.3 ohm 25 watt ceramic resistors I bought in case I needed to replace the one on the Rectifier board. The highest wattage resistors I have otherwise are 1 and 2 watters. Dunno if Rat Shack might have them??? Or I will find one tomorrow somewhere. I have many options here in the Southern California area fortunately.
NO CONTINUITY TO THE HEATSINK!!!! What happened to the mica insulators - they are the rarest piece on there... you NEED them. That continuity could VERY WELL be the problem.
