Hi AK,
I have an SX-440 I bought that was labeled non working. When I got it I did some bench tests and it seemed to be fine, so I decided to go through and recap it and replace the known bad transistors as practice for the many, more complicated receivers I have on my pile
I replaced all the 2SC871 and 2SC870's with a matched set of KSC1845's, double checking the the orientation of each
I replaced all the caps a except for the tuner board
I rebuilt the power supply board
After each component I brought it up on the dim bulb to make sure I hadnt shorted anything, testing with FM along the way
I set the bias to 10Mv as per other threads
In the end I was very happy and went to plug in my turntable and the phono is just dead. Nothing. I realized I don't know that it ever did work as it wasn't something I originally tested.
Aux and AM/FM are fine
I rechecked my work and cant find anything immediately suspect and so I'm not sure where to start.
Any ideas?
Thanks in advance!
Any ideas?
Thanks in advance!
