micrometer
chameleon
Pin 20 - 13.89 vdcPin 20 on the RF Assy bd is the main B+ for the tuner. Check for 13.7Vdc there. Follow it downstream to
a.) H1156 Pin4, Pin 5 (Both 11.2v), Pin 1(13.7V)
b.) Q105 & 106 Emitters (no voltage given) These are 2sa725's known troublemakers. replace with KSA992's.
c.) Selector (S3) Wafer 2 Front pin 2 (13.7V). With Selector in AM Check pin 3 for same voltage, then Pin 2 HA1137 (1.9V). In FM Check pin 11. Should be 13.7v. if not check for dirty contacts on wafer or burnt/lifted contact arm. Lift one side of L102 (or remove from circuit) and check voltage at pin 11 again. If 13.7 now,problem lies in area downwind of L102. If still low, follow schematic to Pin 14 on HA1156W. Check pin 14 voltage.
d.) Pin11 on HA1137. Should be 12v.
a. H1156 - Pin 4 -12.16 vdc; Pin 5 - 12.17 vdc; Pin 1 - 13.66 vdc
b. Q105-106 were replaced with new KSA992FBU's. ECB were different on KSA992 and properly fitted.
c. S1-2/2 Pin 2 - 13.73 vdc; Pin 3 - 1.86 vdc not 13.7
HA1137 - Pin 2 - 1.922 vdc; Pin 11 - 11.76 vdc; Removed one leg of L102 - Pin 11 - 11.87 vdc
HA1156 - Pin 14 - 3.87 vdc
d. HA1137 - Pin 11 - 11.89 vdc
