I pulled the selector switch off the PCB. There were a lot of layers that had to come off to get there. I sprayed all four sides of the two wafers with CRC-QD and wiped them off with a cotton swab. Next came D5 and wiped off with a cotton swab. I worked the selector back and forth about 40 times.
I used a 4 power loupe and watched each copper riveted pin (all of them) flex up as I rotated the selector switch copper ring to insure good contact. I did bend down S3 2/2 F Pin 3 and it now flexes up when the rotor is turned. I did not use any sandpaper between the contacts.
Since I have this switch out, should I perform any other tests? Continuity?
