merlynski
Curmudgeon Electronicist
Where I am going with troubleshooting is to get the center voltage and bias set correctly, so the amp does not clip at high signal levels. When the driver and output transistors on this power amp architecture are replaced this has to be done from scratch. In order to get this done properly the power supplies have to be right (within 10% anyway). It is probably not getting a dead short, but with the center voltage and bias not set correctly the amp will clip asymmetrically way before the output reaches its rated output power level. This can cause excess current through the output transistors, and blow the fuse. If the amp is being over-driven by a larger than expected input like a smartphone or CD player, or even turned up too much with a normal signal it will blow the fuse. This is not a failure, it is normal protection activity to keep the amp from going up in smoke. The only way to really know if the amp is performing up to its rated output is to get the power supplies right, set the bias and center voltage close to norms, then put dummy loads and an oscilloscope on it, drive it with a sine wave and measure it, readjust, remeasure, etc.
It can be adjusted 'close enough for government work' with a DMM, but to get the most out of it is beyond kitchen table hobbyists. I am sure that is why the procedure is not in the normal Service Manual. This is not meant to be disparaging, just stating facts, forgive me if it seems too blunt.
FWIW, the owner may just need a more powerful amp for the levels he wants to listen to with his speakers.
Not much you can do about that
