Yes I know there is a lot of information around and more than 50% who make a recap on the SX-737 are going to change the filter caps as well.
BUT is it really necessary and if YES, will you have a really audible difference to the original filter caps?
My filter caps 6.800µf/ 50V look still good and have these values
No 1: 7.200µF 1.4 esr and 0.9 vlos
No 2: 8.170µF 9.4 esr and 0.9 vlos
What is your advice? And if I should change them, what about putting on some bleeder resistor as well.
But here comes the same question, is it necessary, recommended and if yes, which one?
I have already other filter caps in stock but the 6.800 have only 6.200µf, while my new 10.000 vary between 8.500 and 9.300µF.
Since the newer ones are smaller in diameter I will only change them if there is a good chance, that I will have an advantage.
My main concern is, not to but too much stress on the power supply with much higher µf like anything above 10.000.
Personal will rather prefer something between 6.800 and below 10.000, except you can recommend a perfect match for this lovely SX-737.
