I need some help on the power amp on my SX-737 after an unsuccessful renewal attempt.
What was done before!
I changed caps and transistors on the power supply, protection circuit, equalizer assembly and as last one the power amp.
All DC voltages have been good at the power supply and were even better after the renewal.
The receiver was running before I started the job, but now I probably have killed on the power amp at least the two 2sb530 (Q13-14).
I finished all caps, the four trimpotis and changed all the transistors Q1 until Q10. Only the 4 Output Q11 – Q14 I did not touch so far.
The q1 – q4, 2sa726 were replaced by SA992
The q5 + q6, 2sc1451 were replaced by SC3503
The q7 + q8, 2sd357 were replaced by SC2073
The q9 + q10, 2sb527 were replaced by SA940
First I powered up with the DBT for about one minute and everything looked great. Next I set it up accorting to the sm to check the bias and idle current, this time without DBT.
The trimpotis have been preadjusted to the old values I measured before.
It locked good as well in the beginning, only the idle current was above 200mV on both sides and I could not get it below 30mV. Even with the trimpotis turned fully left, which was very strange, it didn’t get lower.
Then an unexpected bang, now smoke or smell, so I switched power off to prevent further damage.
Without power I figured out, that the case of the two 2sb530 hat contact to ground. After a second recheck, I found one mistake, two caps mixed and installed at the wrong position. The C10 was in the position of C20 and vice versa. C9 and C19 are sitting in the correct place.
But could this be the reason for the shorted Q13 and 14?
And the other question, why did I have to turn trimpotis VR 3+4 fully left without achieving 0VDC?
The four caps are out again but according to the tester are still good. The same with both q9/10.
What I don’t understand, my tester shows no malfunction on the four output transistors q11-q14 but before I had on both sb530 contact between case/collector and ground.
Now I have all four outputs removed, but now clue what to check next and to carry on. Without knowing the reason for the kill, I wound install new outputs again.
