Started on Sunday my planed SX-737 recap project, hoped everything will go well, but it didn’t! Now I need some ideas and help.
Let’s start step by step.
It’s a 220V GN Modell with an AWR-057 power supply. First test on DBT went well, bulb dimmed an it played music with tuner selected, nobody worked on it before.
I will make a full recap and swap most of the old transistors.
With the power for one hour unplugged, I started with the AWR-057 as first board. While trying to loosen the lines and removing them from the retainers, suddenly I produced a spark
in the area of pin 11 – 9.
My mistake
, because I expected the big filter caps had already bleeded and didn’t recheck that or discharged them, just to be sure.
So continued with the change of all electrolytic and the four Transistors.
But I have to admit, this board is really hard to work on, especially on the area of pin 12 -21.
The first test was again with the DBT, but this time, the bulb stays bright….Sh...
As next, I removed all four outputs Q11-14 from AWH-033 and both STV-4 to protect them from potential damage.
Second test again with the DBT, and still the bulb stays bright….
Tried with my little knowledge to isolate the problem I expect going from pins 9-11 to the other boards, but no success.
Now compared that AWH-057 with my second 737 working unit and measured the resistance from every pin to chassis ground, hoping to find the cause, but wasn’t successful so far.
The unit was not connected to power after the second DBT test for any testing.
I don’t want to continue with the protection board, as long that short circuit is not solved.
Tried to find the issue by myself, but now I hope for some ideas and every help is welcome to bring this lovely receiver back to life.
My mistake
- Both SD313 where replaced by KSC2072, same pinout as the old ones
- Both SC945 where replaced by KSC2383, same pinout as the old ones
- All Caps and transistors were several times rechecked for the correct pins, just to be on the save side.
