Pretty sure you mean 2SD357But what about the 2SB527 and 2SB357?
^^ Note that the list is from MTF! Gold standard.
Stay with that. Identify and replace any bad parts to get it working before you replace any other partsI have new diodes available, but this board has very bad and unstable traces and I already lifted some pads while desoldering. So at this stage, I would prefer only to swap the identified bad parts.
Never had so much problems with desoldering like on this board.
@pa_200 I noticed a couple of times you tried to post the user notice with the @ symbol, but you put a space between the @ and the username. It only works with no space after the @.
The voltage is
Q3 E= 13,2vdc, C= 37,4 B= 13,8
Q4 E= 13,8vdc, C= 37,4 B= 14,3
If I compare the voltage with the working tuner, the voltage is
Q3 E= 13,4vdc, C= 29,6 B= 14,0
Q4 E= 14,0vdc, C= 29,6 B= 14,5
