re Buzz : something to think about and to look for
now, looking at the 850, WHERE the ground goes is important:
the AWR-101 power supply has the SAME split ground situation,
20 & 21 are limited to the grounds of the filter capacitors, which should be separate wires back to the ground point, as they hit the center taps of the transformer and thus carry AC current on them, which the ac current will act in concert with the resistance to true ground and cause the line to hum.
while
1 & 12 are regulator references. also chassis grounded, but not sharing any wires to the star ground point.
I ended up buying this 3900 from Raccoon and fixed the hum issue yesterday. I want to post the fix in case someone else runs into this issue- i'm guessing this would apply to any of the receivers in this series. The solve- as mentioned by Raccoon, the previous owner had been in the unit prior and had done some repair work. There are 2 black ground wires going to pin 6 and 7 of the amplifier board. I was checking grounds, when I grounded pin 3 of the PS board the hum got cut in half- that's odd i thought. So i followed the schematic grounds and discovered the previous owner had reversed the grounds. Once I swapped them around the hum is now gone.
Cheers
Thank you for the follow up.
That makes sense.
The pin 6 ground is a current return path (pin 3 awr-210) and reference from the protection circuits back to the power supply, and they are purposefully isolated from the amplifier.
The pin 7 ground is a signal ground reference and slight (quiet!) very low current return (pin 21 awr-210) from the input stage of the channels.
on the power supply board there DELIBERATELY is no connecting foil between pin 3 and pin 21.
A power return ground can constantly vary a bit due to the current flowing interacting with the resistance of the ground path. If there's AC current on that - you hear hum.
Imagine the nightmare of hum between the grounded center tap of a transformer secondary and the main storage capacitors.
That is why grounds are not confused, or interchangeable.
while
